Majorninth
Sep 28, 2017Aspirant
First time loss of connection rbr50 after update to 2.0.0.74
System purchased in july. Connected with only defaults. No guest Network. Connected to main netgear router n750. Double NAT. System updated automatically to 1.12.0.18. All worked perfectly. In Augus...
DarrenM
Oct 02, 2017Sr. NETGEAR Moderator
Have you tried to factory reset the unit since the 2.0 update? Also make sure beamforming and mumimo are enabled in the advanced wireless settings. If you still have disconnects send me a PM with contact info and will have our support team work with you.
DarrenM
