Majorninth
Sep 29, 2017Aspirant
First time loss of connection rbr50 after update to 2.0.0.74
System purchased in july. Connected with only defaults. No guest Network. Connected to main netgear router n750. Double NAT. System updated automatically to 1.12.0.18. All worked perfectly. In Augus...
DarrenM
Oct 17, 2017Sr. NETGEAR Moderator
If you are experiencing disconnects send me a PM with your name,email, and phone number and I will get you in contact with support to troubleshoot the issue.
DarrenM
Majorninth
Oct 18, 2017Aspirant
I started this thread on 9/28. Latest update. This morning my satellite was showing a blue ring. Then it was off. I don't remember if it went white at all. Continued to work fine. Everything has been working fine as far as i knew untill tonight. Tonight while doing light surfing orbi went disconnected. This has been the first failure since I started this thread. There were no ring lights on either the orbi main or satellite. Ssid was 5bars on all bands on both routers. Orbi app and consoles were unavailable. Pressed sync button on orbi main. Blinking white on main no ring lite on satellite. Came back online. App and consoles functional. Back on line. Orbi app now has a red bar displayed that says reboot router.
- TexBuckOct 18, 2017Aspirant
Saw an error in my original post, and want to clarify that the other mesh system I tried after Apple was the Eero system which could not consistently maintain a XBOX Live connection.
________________________________________________
I hope I don't sound like a Netgear fanboy here, I am not. My Orbi has just worked better than anything I tried so far. Try to make a long story not so long.
- I had an Apple Extreme Router and the signal was weak in some parts of my house and I would get red bars and poor connections on my one or both of my XBOX 1s, but other than that worked fine.
- Ordered Eero - worked great 99%+ of the time, but every couple of hours would momentarily drop (< 1 sec ) and kick both XBOXs off line. Great friendly Tech support, but didn't know how to fix it and acknowledged it was an issue. Returned while in 30 day window.
- Bought upper line Netflix with 2 range extenders. Never could get the range extenders to work with XBOXs. But chased a wierd problem that didn't allow one or both XBOXs to host online games. Well after the 30 days finally tracked down the router was setting up NAT to closed. Linksys said it was impossible to have 2 XBOXs on the same router. I infomred it sucessfully worked for years on the Apple router, said it was impossible.
- Went to Micorsoft store, and they said routers are very finicky keep on buying them figuring out what works and return the ones that don't. My Netgear trial cost was $600+.
- Got my Orbi at Costco, lifetime satisfaction guarantee. Specifically checked, if a firmware breaks it in a year, can bring it back.
If you are looking for a company that is perfect, I hope you find it and please email me the answer.
I do admit I am very surprsied at Netgear for the following reasons:
- I assumed I could roll back firmware and have what I started with and it would still work. The rolling back firmware doesn't really go back to firmware is surprising
- It seems like these companies would have one person that actually responded to their forums at some point. If the attitude is we don't care and don't read it, I would think the way to maximize profits for the shareholder would be to shut down the form.
- Maybe it is cynical, I don't really expect anybody to provide any good answers. I do hope they are lurking to know what they need to focus on for the next update.
Good luck and let us know if you find a better solution!
Modern
