DorkiOrbiFW
Jan 24, 2019Apprentice
FIX - Orbi Firmware 2.2.1.210 Performance Issues
Hello Orbi Community,
If any of you are struggling with performance issues with your Orbi system that is currently running on FW version 2.2.1.210, you are not the only one. Countless amount of...
Chuck_M
Jan 25, 2019Mentor
I was glad to see this post -- as it furthers understanding of what makes Orbi tick...
I was also thinking that it would be great to have a thread or series of threads that have a library of telnet functions as they apply to Orbi -- as well as html addresses that may be unknown (IP/debug as an example).
As an example, On a previous post of mine, there was a sequence of telnet commands that turned off the radio backhaul channel if you had wired backhaul. I have seen several others to do some pretty interesting control/configurations.
I think it would be very useful to see all of those different types of commands in a central place.
DorkiOrbiFW
Jan 25, 2019Apprentice
To see pretty much every command you can do to Orbi via telnet, hit the tab key when you’re in a telnet session and your Orbi will populate all the commands available for you to utilize. At least that’s what I did one time when I was just trying to remotely resync an Orbi unit.
PS: Love that idea!
