DorkiOrbiFW
Jan 24, 2019Apprentice
FIX - Orbi Firmware 2.2.1.210 Performance Issues
Hello Orbi Community,
If any of you are struggling with performance issues with your Orbi system that is currently running on FW version 2.2.1.210, you are not the only one. Countless amount of...
DorkiOrbiFW
Jan 25, 2019Apprentice
FURRYe38, I tried disabling the daisy chain as I also saw the same theories you mention. Unfortunately, it only made things worse on my end.
Jan 25, 2019Guru - Experienced User
Ok, Hopefully next FW upate will be good for you.
We just love to troubleshoot the Orbi. :smileywink:
Good Luck.
- JedariusJan 28, 2019Initiate
Thanks for this!
I'm sure 2.2.1.210 is fine for other folks, but I was getting constant random reboots on 2.2.1.210 despite hard resetting and troubleshooting.
I did manage to stop my Orbi from auto updating to 2.2.1.210 with this method and have been running stable on the previous firmware (2.1.4.16). Thanks!
My suggestion to Netgear still stands: please give us the option to turn off the auto update from within the GUI itself.
- FURRYe38Jan 28, 2019Guru - Experienced User
Looks like it will be forth coming:
Jedarius wrote:
Thanks for this!
- DorkiOrbiFWJan 28, 2019Apprentice
Jedarius, I am pleased to hear that my solution has worked for you! Here's to continuing to troubleshooting the Orbi! Also, just got notified today by a Netgear representative that they will FINALLY be disabling forced auto-updates in the upcoming firmware releases!
Jedarius wrote:
Thanks for this!
