Pirc
Mar 12, 2020Aspirant
Fixed IP connection to RBR20
Hi all, I've a configuration of an ORBI AC2200, with a RBR40 (firmware 2.3.5.30, operation mode router) connected to the basic ISP-provided router via a LAN cable. From that I have 3 scattere...
Mar 12, 2020Guru - Experienced User
What is the IP address range that you have static IP adddresses assigned to these computers?
For an example, you can set the IP address range FROM and TO on the RBR as follows:
192.168.1.100 to 192.168.1.200.
Then on either side of this IP address pool, assigned static IP addressed devices. Don't assign anything with in the this range. This range is meant for IP Address Reservatations that are set ON the router. Anything out side this range can be used for static assigned devices.
Pirc
May 08, 2020Aspirant
The 3 devices connected via LAN are:
192.168.15.10
192.168.15.11
192.168.15.240
I've been trying to find that option you mentioned with no success =/
