petercw2
Jun 09, 2017Follower
Fixed IPs?
I'm investigating this device and due to home automation I have many fixed network IP addresses assigned for different devices (home theater, NAS, etc). Wondering if Orbi will allow me to do that as well and if Orbi comes as a 10.1.1.1 setup, and if not allows you to switch it to that range? Thanks!
1 Reply
- st_shawMaster
You can reserve an IP address for a particular device based on the device's MAC address, such that the Orbi DHCP server will always hand-out that address.
By default Orbi uses 192.168.1.1/24 for the LAN. You can change the LAN subnet if desired.
The manual is here:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
