rpcathey
Mar 23, 2022Aspirant
Flashing Amber on 1 plug in satellite
We have an Orbi Mesh system that we use with a fiber optic internet connection. We have 3 plugin satellites and 1 is flashing amber and we can't get it to do anything else. We did a factory reset on t...
rpcathey
Mar 31, 2022Aspirant
Thank you for the help, but we do have the RBW30, plus I only have an Android phone and Ipad with me. Our main router works fine as well as 2 of the satellites. The 3rd satellite that has the amber light may have been exposed to rain, although not directly.
Mar 31, 2022Guru - Experienced User
moisture is the death of electronics.
And if its a rbw30 with the issue, you're a little bit stuck as there isn't a factory way to hardwire into it to force new firmware to it.
so you might be SOL
- rpcatheyMar 31, 2022AspirantThank you, that's what I suspected but wanted to see if others thought the same thing.
