dcr_60's avatar
dcr_60
Force 2.4GHz only to connect smart devices
FURRYe38   The referenced articles are from 2018 and the it appears the "where" in the UI and/or the how to broadcast only 2.4 has changed. Any ideas?
Thanks in advance.
  • So you might want to also change the power output of the 5Ghz radio to 25% on the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings. Turn OFF any RBS temporarily. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
  • FURRYe38's avatar
