MKazan's avatar
MKazan
Force connect a device to 2.4 Ghz on Orbi RBR50
I have a PS4 that sits a bit far from the orbi router. Its connected to the Router on 5 Ghz but the signal indicator in the mobile app shows the one bar only. This is leading to losing connection frequently. I know 2.4 ghz gives me a more stable connection. How can i connect my PS4 to 2.4 ghz only?
  • Please mark your thread as solved so others will know.
    Enjoy.
    • MKazan's avatar
      MKazan
      This is exactly what i wanted!!
      You are amazing thanks! I was always looking at the router to solve the problem, and totally ignored The console
      • FURRYe38's avatar
        Enjoy.
