ckfox4
Apr 07, 2019Follower
Force Device to Orbi Satellite/Router
Hello,
First time poster after switching from an Asus router to Orbi.
I am having issues with my mesh speaker network and Orbi; After significant amount of troubleshooting I can see that ...
tucsontico
Apr 07, 2019Virtuoso
I am using the Bose Soundtouch as my mesh speakers (over 2 years) and do not have the issue you noted. It sounds as if you have the router and satellite(s) too close together. Try moving the satellite(s) at least 30 feet (10 meters) away from the router. Are there other WiFi signals nearby? Interference from competing WiFi sources can also cause similar dropouts/crashes. Try setting your ORBI to Ch 1, 6, or 11 for 2.4 gHz and Ch 36, 40, 44, or 48 for 5 gHz. (You can get apps to analyze the WiFi signals in your house from various sources.)
Also, a factory reset of the ORBI system may help solve the issue. If you resort to a factory reset,be certain to reconfigure your system from scratch. Do not use a backup config file as there could be corrupted data in that file causing your issue.
