SLK-Purdue
May 26, 2020Luminary
Force RBR50 to TFTP for un-brick?
I purchased a cheap broken RBR50 on ebay to get some replacement plastic parts. Got the parts I wanted and now I want to play a bit. Orbi has pulsing white LEDs and solid green power LED. No oth...
CrimpOn
May 26, 2020Guru - Experienced User
SLK-Purdue wrote:Orbi has pulsing white LEDs and solid green power LED. No other obvious signs of life. Feels like bricked firmware. Is there a jumper that will force TFTP reload? I have tried 30-30-30.
I had to TFTP firmware recently because I bricked my spare Orbi and remember that it was not as easy as it should have been. Did you try the TFTP without "seeing amber"? There was a comment on the forum in the past 2-3 weeks claiming that the TFTP should start immediately, rather than waiting for 10 flashes like the directions say.
