SLK-Purdue
May 26, 2020Luminary
Force RBR50 to TFTP for un-brick?
I purchased a cheap broken RBR50 on ebay to get some replacement plastic parts. Got the parts I wanted and now I want to play a bit. Orbi has pulsing white LEDs and solid green power LED. No oth...
pbarham
Nov 21, 2020Apprentice
Oh.... just came across this post which looks very interesting: https://community.netgear.com/t5/Orbi/Orbi-RBR50-seems-stuck-in-boot-loop/m-p/1948614/highlight/true#M98222
Somethign to investigate tomorrow.
SLK-Purdue
Nov 22, 2020Luminary
If you can get into U-Boot, there are lots of options and you can almost certainly de-brick the router using the internal serial port. I have attached info on that. In my case, the U-Boot in flash got corrupted. I want to reprogram flash in some way to clean up the corrupt U-Boot.
Scott
