ydlazkov
Jun 04, 2019Tutor
Force Satellite To Specific Device
Hi, I bought additional Orbi Satellite AC2200 to connect to our RBR40 router. Our wifi setup now have 2 satellites. The devices, (laptop, security cameras, and doorbell) nearest to the new satell...
Aug 14, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
ydlazkov wrote:Hi,
I bought additional Orbi Satellite AC2200 to connect to our RBR40 router. Our wifi setup now have 2 satellites. The devices, (laptop, security cameras, and doorbell) nearest to the new satellites are still connecting to either the farthest satellite or to the RBR40 router.
How can I force the devices to connect to the nearest satellite?
I tried turning off the farthest satellite for a moment, but as soon as I turn it back on, the devices would again connect to it or directly to the router.
I read another post similar to my issue but the suggested option is inconclusive.
