Boston182
Nov 20, 2018Aspirant
Force Vizio to Satellite Instead of Router
Hey all, so here's my situation: I've got a Vizio E-Series (e65-f1) and it loses connection intermittently. When I do a soft reset, it works for the remainder of that power cycle. When I turn it on...
Boston182
Nov 22, 2018Aspirant
Yep. Changed it to 50% and am still having the same connectivity issues with my TV and now most things connect downstairs.
Nov 23, 2018Guru - Experienced User
Ok, lets put the power levels back to 100% then turn OFF the satellite up stairs and run just the Orbi router down stairs...
- Boston182Nov 26, 2018Aspirant
Doing that seems to be bogging down the wireless on other devices when in distant corners of the upstairs.
I think I'm just going to bite the bullet and hardwire the TV unless you have any other solutions?
- FURRYe38Nov 26, 2018Guru - Experienced User
If you can get wire connect...definately recommended. Seems like bad wifi behavor on this TV.
