juankt
Oct 22, 2021Aspirant
Forced Firmware updates BRICKED AP mode
I have the Costco Special RBK753 (AX4200) recent "forced" firmware updates have "bricked" the ability to run them in AP mode. Firmware versions 3 and earlier were perfectly fine and completely flawles...
Oct 23, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Actually all FW versions support AP mode on Orbi AX systems. I just had my 8 series in AP mode for a while, now it's back in router mode. Blocking isn't needed while in AP mode.
Thank you.
- juanktDec 09, 2021Aspirant
Actually the AP mode while it's appears to be supported causes the Satellites to FAIL to connect over wifi. I've tried this with three separate ORBI RBK750 sets. Moreover it's quite easy to repro...
Repro:
- Configure RBR750 in router mode
- Connect to satellites using wifi (standard procedure)
- Update to latest firmware 4.6.5.14
- Move the wired connection to the local network FROM the internet port to one of the Ethernet ports
- While connected wirelessly to satellites login to Router and change to AP mode.
- Wait for router to come back up.
- Both satellites will NEVER connect wirelessly Indicators remain Purple and Router "connected devices" page shows the satellites as "Disconnected"
- wwlen1Dec 09, 2021GuideMove the wired connection to the local network FROM the internet port to one of the Ethernet ports.
That's the problem.
Unlike most other routers where you are expected to do this, the Orbi stays in the internet port.- juanktDec 09, 2021AspirantThat is NOT correct, I ran sucessfully in AP mode for MONTHS exactly as I described... In face if configured in AP mode and connected local network to the rbr the light indicator on the RBR would show purple. Finally, I've tried leaving the hard wired connection in the "internet port" it does NOT work.
