juankt
Oct 22, 2021Aspirant
Forced Firmware updates BRICKED AP mode
I have the Costco Special RBK753 (AX4200) recent "forced" firmware updates have "bricked" the ability to run them in AP mode. Firmware versions 3 and earlier were perfectly fine and completely flawles...
wwlen1
Oct 23, 2021Guide
If you are running in access point mode, then you have another router providing the routing functions.
In that case, you could just block the Netgear sites using the blocking functions on the primary router.
juankt
Dec 09, 2021Aspirant
Wow I'm amazed at how people do not actually read posts. The principal problem is that Satellites RBS will NOT connect to the Orbi Router RBR via wireless the MINUTE you enable AP mode. My devices that are close (with the most recent firmware) can connect to the router but the router will NOT connect to the satellites. They stay purple.
