westner99
Jul 08, 2023Tutor
Forcing 2.4 Ghz WiFi on Orbi RBR50 Guest Network
i have a Netgear Orbi router with both 5 and 2.4 G WiFi networks. I have some devices that specifically require a 2.4 g network but sometimes only the 5g network is available. how can i force Orbi to...
- Jul 08, 2023
Turn OFF all RBS first. Change the power output of the 5Ghz radio to 25%. Under Advanced Tab/Advanced Settings/Wireless Settings
Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Be sure that 20/40 MHz Coexistence enabled.
westner99
Jul 10, 2023Tutor
I don't know if you realize that you're talking to a total noob. RBS?, RBR?, - have no idea what they are, but throttling down the radio signal of the 5GHz network worked. Once I set up the App on the Guest Network, everything was OK.
Thank you for the reply and teaching me something about my Orby.
Jul 10, 2023Guru - Experienced User
RBR is the router unit.
RBS is the remote satellite unit.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
