sethm1
Aug 15, 2020Guide
Forcing a device to 2.4 ghz
I am not seeing this an option in the settings, so may not be possible - that is, have a number of devices that i am sure can handle 2.4 & 5 ghz, so can i assign 2.4 to a specific device or am I stuc...
sethm1
Aug 15, 2020Guide
Thanks crimpon for the explanation. I came from the R7000 nighthawk and there yes had 2 ssid's. Makes sense now.
Mstrbig
Aug 15, 2020Master
If it has the feature, You can disable the 5G network on the device and force it to connect 2.4G only. I have a Windows 10 laptop that has issues with 5G. I went into device manager and disabled 5G by changing a few settings.
