80sTiger
Oct 30, 2017Tutor
Forcing Router DNS / Blocking Port 53 @ Clients
Having just upgraded to Orbi, trying to duplicate my configuration around forcing devices in my home to use the DNS defined manually in the router and not allowing individually connected clients to o...
ElaineM
Nov 01, 2017NETGEAR Employee Retired
Welcome to the community, 80sTiger
Which model number you're working on previously?
Can you post screenshots of the configurations?
Did you try resetting the unit?
80sTiger
Nov 01, 2017Tutor
Previous model was AC750/R6050 ... config screenshot below worked fine in previous router (DNS worked fine for 192.168.0.1 DHCP'd to clients, blocked any manual set DNS on clients), but now same config blocks all DNS at clients with new Orbi - nothing resolves. I have indeed rebooted.
- ElaineMNov 03, 2017NETGEAR Employee Retired
Let me check this with our engineers.
- 80sTigerNov 04, 2017Tutor
Many thanks for checking. Just to be clear, on the previous Netgear router, when I had this service blocked (DNS) on this IP range (.2-.254), excluding only the router itself from the range (.1) and pointing all clients to the router (.1) for DNS resolution, everything worked/resolved just fine, and if a client tried to manually override their local DNS (which is the router at .1 issued via the router's DHCP), then nothing on the client would resolve correctly as the DNS traffic is blocked. Thanks.
- ElaineMNov 08, 2017NETGEAR Employee Retired
Kindly register your device so that we may log a case.
