naccnacho
Dec 23, 2017Follower
forgot wifi password
i have recently changed the wifi password to my orbis wifi and now i dont remeber it and cant connect to it
guzzijason
Dec 23, 2017Apprentice
If you can't get into the admin UI via a wired connection, then perhaps your option of last resort would be to reset to factory defaults and set everything up from scratch. Good luck!
