Guapo_Apo
May 09, 2017Aspirant
Foscam C1 Cameras
Hi, Hoping someone can help me so I can keep my Orbi! I have several Foscam C1 cameras that operate only on 2.4ghz frequency. When setting up, my phone needs to be connected to a 2.4ghz sig...
- Jun 01, 2017
Turns out the fix for me was not to plug each camera in via cable, but rather to DISABLE Enable 20/40 MHz Coexistence for 2.4 ghz band via ADVANCED > ADVANCED SETUP > WIRELESS SETTINGS. Hope this helps others.
Guapo_Apo
Jun 01, 2017Aspirant
HI,
You need to plug in each Foscam camera, one at a time, into your Orbi router via an ethernet cable and then configure.
Good luck!
Miles267
Jun 01, 2017Apprentice
