Retired_Member
Jan 15, 2019Frequent Connectivity Issues
Hi there. I have an RBR50 Orbi Router with 1 Satellite (RBS50) - both are running firmware V2.2.1.210. I am experience frequent connectivity drops on multiple wifi devices, often 1 or 2 times per h...
Retired_Member
Jan 15, 2019Hello Furreye38 - thanks for your response and questions...
Firmware on both the router and the satellite is V2.2.1.210
The ISP that the router is connected to is made by Alcatel-Lucent, model G-240g-a
Square footage of our home is 2500sf.
The satelite is located about 35ft from the router.
2.4Ghz Channel is set to auto; 5Ghz is set to 48.
We live in a very rural area, and we only pickup the wifi from one neighbour, plus their signal is very weak in our house, if at all.
We are using WPA2-PSK[AES] security.
I will try setting the 2.4Ghz channel to one that you suggest. You also mentioned bandwidth saturation... is there anyway to test for that before I spend more $ on a second satellite? Any suggestions welcomed!
Jan 15, 2019Guru - Experienced User
Has the system been factory reset and setup from scratch after the FW update? Just checking.
One way would be to turn off as many device, and start by connecting maybe just a few. Do some normal routine stuff. See if anything changes. Then start turning ON devices and see if where and when you notice something happen again.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
