Moffy
Jul 01, 2018Follower
Frequent network drop on Orbi RBK50
ok have a RBK50 home setup latest firmwear and keep haveing network drops WIFI and wired ....have factory restet and still the same any help would be appreciated you dont seem to get help from netgea...
Jul 02, 2018Guru - Experienced User
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and other unused channels on 5Ghz.
Disable MIMO, Daisy Chain and Fast Roaming.
Whats the distances between the router and satellites.
Whats the distances between the router, satellite and TV?
What is the Mfr and model# of the ISP modem the Orbi is connected too? Built in router here by chance?
