Steve933
Sep 14, 2019Aspirant
Frequent "No Internet" -- STILL
Various wireless devices (laptops and tablets running different OS's) experience frequent loss of internet connection. It affects devices independently--the internet connection is still up on other ...
ekhalil
Sep 15, 2019Master
Steve933 wrote:.........The purpose for the ASUS is to connect to 2.4 devices that have a problem with the fact that Orbi broadcasts the same SSID for 2.4 and 5 wireless networks (it's a problem for my Harmony hubs). .......
Steve933 What issues do you have with Harmony hubs? I have a Harmony Ultimate and Harmony Elite hubs connected to Orbi. Working just fine on the 2.4 GHz band on the common SSID.
If Harmony does not work together with your Orbi then you must have some other issues in your network, I guess!
- Steve933Sep 15, 2019Aspirant
I have two Harmony hubs. When I installed the Orbi, I began to have problems with extreme latency when using the remotes. It didn't happen all the time, but it happened to both hubs intermittently. It could take anywhere from 30-60 seconds for the channel to change after pressing a button, for example. I searched the internet for a solution and found a "theory" that the single SSID was confusing the hub. The recommendation was to configure it to connect to a specific 2.4 network. I did that and haven't had the delay since.
- ekhalilSep 15, 2019MasterIt could be some residual configuration in the hubs if you used them previously with another router.
I would factory reset the Harmony hubs and set them up again with Orbi.
As I mentioned both of my Harmony hubs work flawlessly with Orbi.- rlopapa2019Sep 15, 2019TutorI have two Harmony Hubs as well (purchased after my Orbi and they have worked flawlessly for over a year - never had any latency issues.
