VVPath
Aug 18, 2018Follower
Frontier Compatibility with Orbi
I can't solve the IP address redundancy problem on my Frontier FIOS Router and Orbi Router and my Frontier service will not assist me in turning that into bridge mode. I searched online and used some...
Aug 19, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
