Goodtimes481
Jul 08, 2020Tutor
frustrated Netgear makes the decision to put 43S in star mode when I want it in mesh (Daisy Chain)
Hi I just purchased the Orbi rbk 43s ( sorry I chose on top rbk 53S that was the only one listed or allowed me to chose) from Best Buy and it's the 3 pack. The performace of the product as far as sp...
- Jul 11, 2020
It does have the option to daisy chain (mine does) but its more the router is able to figure out if star or daisy chain is going to be more efficient. Why would it setup in daisy chain if star worked better for speed? You might have just had it to close as the orbi devices need minimum of 30ft of seperation to function properly with roaming and configuration.
I'm happy to see you have it working with the speeds you desire.
Jul 09, 2020Guru - Experienced User
if the satellite is 3 ft from the playstation, why don't you direct wire the playstation to the satellite? The satellite is going to have a better backhaul than the playstation.
Plus you can't trust playstations speedtest setup. They're not always using the optimal server.
- Goodtimes481Jul 11, 2020Tutor
The whole Idea was not to have wires, and my post was relating to why put an option to enable dasiy chain if it don't do it. I'm still upset about that. But I did move the satellite away from the kithen behind and up high above cabinets and moved it 20 to 30 ft infront of the router in the livingroom which is further away from his room. yesterday I was able to get in Logan's room when he was not home and tested the reception on my laptop & which I turned on in Logan's room I was able to link my laptop to logan's Node. I was getting an 866 linkspeed and around 350 to 380 mbps on my laptop and phone off that Node. Logan's has not been here but he left his play station on and since I moved the node as mentioned before from up high above the kitchen cabinet's to front part of the livingroom his play station has been in sleep mode or whatever you call it and is now getting the signal off Logan's room node in sleep mode at 433 and hasn't roamed in 36 hours. (I don't go on the play station) so I'm happy for now.
Just as a matter of principal if they advertise this unit as a mesh unit but it works as a star unit there either shouldn't be an option to put it in dasy chain mode. My preference would have been 3 options dasy chain star or auto. then the box or ad wouldn't be misleading. To end this correctly I am very happy with the hardware at around 40 to 50 ft away and connected by by external satellite he's getting full speed. and since I moved that node from the kitchen up high the laundry room, kitchen, logan's room, Logan's dad's room and my room we are all getting 350 mbps speed so I can't complain.
- plemansJul 11, 2020Guru - Experienced User
Thank you for your responce I apprecate it. I'm a new baby and when I got this router I ditched a linksys dual band which was true mesh. On the box it says this was a mesh router thinking dasiy chain. On the Linksys he was getting 30-60mbps on his playstation. I read about tri band and after review after review I chose the orbi. When I first set it up with the kitchen node against the wall high up there was no difference. It freaked me out after spending $370 Plus it was not connecting to the node is logan's room. All and all I moved the kitchen node back off the wall into the front of the livingroom His play station has been getting a link speed of 466 for 2 days stright from his own router. (play station is sleeping the kid isn't home now) When I went to test my laptop and phone I was getting a 866 and 350 speed on speedtest.net
My beef is I just feel if the GUI says daisy chain it should go to daisy chain mode. if Daisy chain is disabled then go to star mode, or make it easier for people who don't like to read instructions have a section that says star mode and also have an option for auto mode. This router acts just in auto mode. I like to play with things during my testing I would have liked to put this in Daisy Chain mode to see the difference since this is tri-band. As long as he can get the signal from his node now and terrific performance I am happy ( thats the overall goal) how we get there is more of the techi stuff. I like to experment
But my friend thank you so much for your your responce and putting up with my Grammar and spelling. with my job I'm always in a hurry. You have a great day!
