Goodtimes481's avatar
Jul 08, 2020
frustrated Netgear makes the decision to put 43S in star mode when I want it in mesh (Daisy Chain)
Hi I just purchased the Orbi rbk 43s ( sorry I chose on top rbk 53S that was the only one listed or allowed me to chose)  from Best Buy and it's the 3 pack. The performace of the product as far as sp...
  • plemans's avatar
    Jul 11, 2020
    It does have the option to daisy chain (mine does) but its more the router is able to figure out if star or daisy chain is going to be more efficient. Why would it setup in daisy chain if star worked better for speed? You might have just had it to close as the orbi devices need minimum of 30ft of seperation to function properly with roaming and configuration.
    I'm happy to see you have it working with the speeds you desire.
