Goodtimes481
Jul 08, 2020Tutor
frustrated Netgear makes the decision to put 43S in star mode when I want it in mesh (Daisy Chain)
Hi I just purchased the Orbi rbk 43s ( sorry I chose on top rbk 53S that was the only one listed or allowed me to chose) from Best Buy and it's the 3 pack. The performace of the product as far as sp...
- Jul 11, 2020
It does have the option to daisy chain (mine does) but its more the router is able to figure out if star or daisy chain is going to be more efficient. Why would it setup in daisy chain if star worked better for speed? You might have just had it to close as the orbi devices need minimum of 30ft of seperation to function properly with roaming and configuration.
I'm happy to see you have it working with the speeds you desire.
Goodtimes481
Jul 11, 2020Tutor
Thank you for your responce I apprecate it. I'm a new baby and when I got this router I ditched a linksys dual band which was true mesh. On the box it says this was a mesh router thinking dasiy chain. On the Linksys he was getting 30-60mbps on his playstation. I read about tri band and after review after review I chose the orbi. When I first set it up with the kitchen node against the wall high up there was no difference. It freaked me out after spending $370 Plus it was not connecting to the node is logan's room. All and all I moved the kitchen node back off the wall into the front of the livingroom His play station has been getting a link speed of 466 for 2 days stright from his own router. (play station is sleeping the kid isn't home now) When I went to test my laptop and phone I was getting a 866 and 350 speed on speedtest.net
My beef is I just feel if the GUI says daisy chain it should go to daisy chain mode. if Daisy chain is disabled then go to star mode, or make it easier for people who don't like to read instructions have a section that says star mode and also have an option for auto mode. This router acts just in auto mode. I like to play with things during my testing I would have liked to put this in Daisy Chain mode to see the difference since this is tri-band. As long as he can get the signal from his node now and terrific performance I am happy ( thats the overall goal) how we get there is more of the techi stuff. I like to experment
But my friend thank you so much for your your responce and putting up with my Grammar and spelling. with my job I'm always in a hurry. You have a great day!
Jul 11, 2020Guru - Experienced User
Again, glad to hear its working.
Sadly the orbi is designed to be more user friendly and less friendly to the more technical of us. They tend to make them simple for the average user.
it kind of leaves the more technical in the cold. But the nice thing is they do function well when they've had time to fully setup.
A couple things I will give you a heads up on, with its bandsteering and roaming. they do take a bit to "settle down" after they're first installed. What I mean is they learn which devices tend to need to be on the 5ghz and will auto connect to that right from the start.
whenever I reset mine or change router configuations, it takes a couple days for my devices that need 5ghz to auto start out on 5ghz.
I rebuild my network frequenly as I'm changing out routers/modem/devices. For this reason (and others) I don't like the bandsteering but the family loves it. so it gets used and I just put up with it for a few days. Its just something to keep in mind that if you're speedtesting with it, one day you can get slow 2.4ghz speeds and the next fast 5ghz. Or vice versa. Its more about how devices are functioning on the system than how their peak performance is.
You'll also notice that Orbi won't give you the peak performance you get from a flagship router. but it will give you better average throughput throughout a home. My RAX200/CAX80/C7800 will all stomp on the orbi if I'm close to the router. But with any distance/obstructions, the orbi shines. its why I use a flagship router and then the orbi as access points in my setup. Its a bit overkill but fun for testing :)
Plus my devices that need >200mbps speeds, tend to be hardwired in. Less than that covers pretty much any of my gaming/streaming scenarios if I'm on wireless.
