JYDLC
Jan 06, 2021Aspirant
FRUSTRATED WITH MY ORBI RBR50v2 AND RBS50's! Keeps dropping connection & ethernet ports wont work!
Help!! My Orbi system keeps dropping connections and my LAN ethernet ports wont work. I recently selected the auto firmware update to 2.5.2.4 ( i dont remeber what the prior version was) and after I ...
Urbangeek
Jan 21, 2021Guide
I have similar issues as you, but its happening to my Satellite.
Current setup, RBR50 as my router. RBS50 using the wifi backhaul. Any devices I have connected to the SAT via the ethernet ports all drop connection randomly at the same time and will reconnect shortly between 20secs to a minute. Devices connected to the SAT via wifi aren't affected. My PC is connected to switch that connects to the RBR50 and doesn't drop connection. So it leaves me to believe there's an issue with the SAT.
Jan 21, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M9702
Urbangeek wrote:I have similar issues as you, but its happening to my Satellite.
