gebert63
Mar 21, 2021Follower
Frustrating WIFI Drops - RBR50V2
We had a perfecting working system (1 RBR50V2 with (2) RBS50V2 Satellites. We received them in a single box as a kit. It ran great for over 15 months and we couldn't be happier with it. About a mon...
sspoly77
Mar 21, 2021Aspirant
I have an RBR50 and I've recently had the same issue. Devices can connect to the wifi, but not the internet. Devices hard wired into the base, or satelites work just fine, but anything wifi doesn't.
I can reboot the router and things will work fine for about 10 minutes or so, then nothing wifi will connect to the internet anymore.
Modem is a Aris Surfboard TM822R
Router is RBR50 with the new update just pushed V2.7.2.104
Orbi is in Router mode.
The issue started before the update was installed I believe, but now it's constant. I can reboot the router and things can connect for a bit, then they just stop working.
vajim
Mar 21, 2021Master
sspoly77 wrote:I have an RBR50 and I've recently had the same issue. Devices can connect to the wifi, but not the internet. Devices hard wired into the base, or satelites work just fine, but anything wifi doesn't.
only you will know that
how often do you update your firmware?
- sspoly77Mar 21, 2021Aspirant
very rarely. It was having some drop issues so I installed the new update. Not sure if it was the same issue or not.
- FURRYe38Mar 22, 2021Guru - Experienced User
Be sure to disable Traffic Meter if you have it enabled.
sspoly77 wrote:very rarely. It was having some drop issues so I installed the new update. Not sure if it was the same issue or not.
- vajimMar 22, 2021Master
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
Factory reset to fix firmware?
