sjameel
Aug 05, 2020Aspirant
FTP connections
I am trying to connect to a FTP site as https://ftp.abc.com from a browser (like Chrome, Brave, Internet Explorer). All the browsers says "This site can’t be reached". When I connect directly t...
Aug 05, 2020Guru - Experienced User
Are you sure thats a valid URL? Doesn't work for me either. www.abc.com works.
Also ftp://ftp.abc.com is not valid either.
If your ISP Modem has a built in router already, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
sjameel
I apologise - I should have mentioned.
The FTP address I put in was a sample one. Not an accurate one.
it is something like https://ftp.deloitte***.com
Now, I have another computer which is VPNed to different company and I can connect using that.
Without VPN, it does not connect.
- sjameelAug 05, 2020Aspirant
My Spectrum Cable Modem does not have Wifi. Just a plain Modem.
I am able to connnect to any other FTP sites, like
I am unable to connect to
Is there any place in the router that blocks this connection?
I do not see it in the Blocked Sites.
sjameel wrote:I apologise - I should have mentioned.
I have disabled the Netgear Armour as well, still not able to connect.
