Mgomez85
Mar 25, 2017Apprentice
Full signal strength but low throughout put
So on my Satellite unit I been having issues with this from day one! I would have full signal but it seems my throughout put would be low to the point the wifi is unusable! I use an app on my iOS d...
st_shaw
Mar 25, 2017Master
If you have a good WiFi connection to the Satellite but slow speeds, then the issue is with your backhaul.
Download iperf3 and do a throughput test between a wired device connected to the router and a wired device connected to the satellite. You should see 500Mbps to 575Mbps. Change the relative position of the router and satellite until you get good throughput.
