Gsmites
Nov 01, 2019Tutor
FW V2.5.0.38 Apple products dropping wifi
Since updating Firmware to V2.5.0.38 our Apple products (iOS 13.2 - Iphone/IPad) keeps dropping wifi connection. All the other devices have zero issues (Nest, Echo, Hue). It's been super reliable u...
Nov 01, 2019Guru - Experienced User
Factory reset the RBR and RBS and setup from scratch.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Have had no issues with my iphone (iOS 13.2) and Mac Book Pro (10.14.6) using the above settings.
Gsmites wrote:Since updating Firmware to V2.5.0.38 our Apple products (iOS 13.2 - Iphone/IPad) keeps dropping wifi connection. All the other devices have zero issues (Nest, Echo, Hue). It's been super reliable until this point and I am getting very frustrated. I've tried different configurations from other posts but nothing works. Please help!
