Gsmites
Nov 01, 2019Tutor
FW V2.5.0.38 Apple products dropping wifi
Since updating Firmware to V2.5.0.38 our Apple products (iOS 13.2 - Iphone/IPad) keeps dropping wifi connection. All the other devices have zero issues (Nest, Echo, Hue). It's been super reliable u...
Nov 07, 2019Guru - Experienced User
Did you try a factory reset on the RBR to see if this help any before going back to v30?
Accutronman wrote:Link speed and throughput with my Apple devices was horrible with 2.5.0.38. I rolled back and everything is fine now.
Accutronman
Nov 07, 2019Guide
Nope. Didn't want to have to re-enter options with a reset. Just downgraded the firmware.
- Retired_MemberNov 07, 2019
Accutronman wrote:Nope. Didn't want to have to re-enter options with a reset. Just downgraded the firmware.
Nice...now no more manual firmware updates
- FURRYe38Nov 12, 2019Guru - Experienced User
Next time you upgrade FW, try the reset. This will clear out problems seen after FW updates. Also be sure to do backup configurations to file for safe keeping. Helps save time. No issues with v38 loaded.
- Retired_MemberNov 12, 2019
FURRYe38 wrote:Next time you upgrade FW, try the reset. This will clear out problems seen after FW updates. Also be sure to do backup configurations to file for safe keeping. Helps save time. No issues with v38 loaded.
factory reset is for lost password
- snoyogi2Nov 12, 2019Tutor
When you say reset, I power cycled all three orbis multiple times trying to resolve the issue. I did not do a factory reset. Yes. I did take a backup. Nothing wokred except downgrading the software. I will wait and hope the next release works better or you come up with better documentation in your release notes on the upgrade process.
