MCO79
Apr 12, 2020Tutor
FWIW Orbi RBR50 dead after power loss
The symptom is Red blinking power light. The unit was running 2.5.1.8 (latest firmware) so it wasn’t in the middle of an upgrade . It was plugged into a power strip as well. Had to run out to best buy...
MCO79
Apr 13, 2020Tutor
Would that still apply for something that has an external DC power supply? It should regulate output I would think. Great idea anyhow, I'll order a Battery backup unit
Apr 13, 2020Guru - Experienced User
Did you try a different power adapter on the original RBR? Power adapters take the hit when power outages happen. The RBR may still be ok, just the power adapter maybe bad...
MCO79 wrote:Would that still apply for something that has an external DC power supply? It should regulate output I would think. Great idea anyhow, I'll order a Battery backup unit
- MCO79Apr 13, 2020Tutor
yeah same problem, even used the old power adapter on the new unit and vise versa . New unit works with both adapters. The unit that died has been flaky in the past. During other power outages I'd have to power cycle it several times to get it to come up. Same syptoms, flashing red light. I just think it was bad from the get-go
- FURRYe38Apr 13, 2020Guru - Experienced User
Possibly.
Get you into a UPS for your router and modem.
Good Luck.
