rcs0926
Jul 06, 2020Aspirant
Games not connecting to Wi-Fi
My Orbi did something today that has never happened before. It isn't allowing gaming apps to connect to the Wi-Fi. There are a couple of gaming apps that are always online, and I've never had problem...
rcs0926
I don't have all that info at my disposal at the moment. I never touched any of the settings for my router, so I don't know why anything changed. It makes sense that it might be an issue with the ISP, but I guess I'll exhaust my options first with the router. When I get home, I'll make sure that Armour and Circle aren't enabled. I'm pretty sure they aren't, but I'll make sure.
Jul 06, 2020Guru - Experienced User
Ok, ya if you haven't touched the orbi system at all and you just started experiencing this issue, I would look more up stream from the router.
