DigitalMan2112
Dec 27, 2018Tutor
Gap in logs?
I was notified by my ISP that they believe there was a copyright infringement on my IP address on 12/25/2018. When I look at the logs I see a huge gap. I see today 12/27 and then it goes to 12/10. I...
Dec 27, 2018Guru - Experienced User
Try a reset on the Orbi router and setup from scratch. Enable the logging that you need and check to see if you still notice gaps in the logs.
What FW version are you using? v210?
DigitalMan2112
Dec 27, 2018Tutor
Am running V2.2.1.210 on router and both satellites.
- FURRYe38Dec 27, 2018Guru - Experienced User
Shouldn't be any gaps however this FW has caused some odd issues. Let us know if you still see this after a ERASE on the router and setup from scratch.
