DigitalMan2112
Dec 27, 2018Tutor
Gap in logs?
I was notified by my ISP that they believe there was a copyright infringement on my IP address on 12/25/2018. When I look at the logs I see a huge gap. I see today 12/27 and then it goes to 12/10. I...
ekhalil
Dec 27, 2018Master
DigitalMan2112 wrote:
........ Also are the add_nat_rule entries normal as I am the only admin and have not been making any changes to the router.
[UPnP set event: add_nat_rule] from source 192.168.1.22, Monday, December 10, 2018 13:01:27
[UPnP set event: del_nat_rule] from source 192.168.1.22, Monday, December 10, 2018 12:38:46
[UPnP set event: add_nat_rule] from source 192.168.1.22, Monday, December 10, 2018 12:31:11
[UPnP set event: add_nat_rule] from source 192.168.1.22, Monday, December 10, 2018 12:03:29
Those events are normal if you have UPnP activated and you have devices in the network.
UPnP is a network protocol that allows compliant devices to automatically set port forwarding rules for themselves. These devices can be personal computers, printers, security cameras, game consoles or mobile devices that communicate with each other and share data over your network.
