Deez72
Mar 03, 2018Tutor
Gave up on Orbi
Had to give up on Orbi today. Still no resolution on the dropping WiFi, and very slow connection speeds. It is too bad NETGEAR has not figured this out. I liked one SSID and not 5 SSIDs for my Tri...
Mar 06, 2018Guru - Experienced User
You might give reverting back FW versions or if that fails, contact NG support and see if they have a beta that you can try out.
Deez72wrote:Had to give up on Orbi today. Still no resolution on the dropping WiFi, and very slow connection speeds. It is too bad NETGEAR has not figured this out. I liked one SSID and not 5 SSIDs for my Triband router and WiFi Extender combination. Sadly I paid well over $400.00 for it, but cannot return it, as it passed my 15-day return policy. Buyer beware of Orbi!
