CarlosA
Jul 29, 2017Follower
Genie App Guest Access
When I log into my router, using the Genie app, I am not able to access the Guest Wifi. It clearly shows me the profile for my already created guest access, however, a pop up comes up and tells me the...
OldGrandpa
Jul 29, 2017Aspirant
And the pop up uses the good English 'This router do not support Guest WiFi', right? Apparently a poor translation from chinese. I recommend writing HONEST reviews of your experience, good and bad, but thorough, on the app market, and on Amazon. Help others to understand what they are getting into by buying this product. First read the community postings and make sure your Amazon review notes that NETGEAR has been removing features with firmware updates (the reason I don't buy anything from SONY any more). Have you tried to see what devices are using your satellites? That's fun also. Anyway, product manufacturers want good reviews, so that seems to be the only place they listen.
