CarlosA
Jul 29, 2017Follower
Genie App Guest Access
When I log into my router, using the Genie app, I am not able to access the Guest Wifi. It clearly shows me the profile for my already created guest access, however, a pop up comes up and tells me the...
DarrenM
Jul 31, 2017Sr. NETGEAR Moderator
Hello CarlosA
Have you logged into the web GUI by going to 192.168.1.1 then you will be able to access the guest network settings.
DarrenM
