HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
May 05, 2020Guru - Experienced User
What browser are you using? Try IE11, Firefox or Opera.
Besure to clear all browser caches.
Reboot the RBR.
What FW version are you using?
Try a different PC or laptop.
- relberfeldAug 26, 2020Apprentice
this is total BS. Netgear changes the name of access control and fails to test this new "secured access" - results in constant 500 internal server errors. Then a "tech" person says the answer is to reset the router and that fixes it. How is that a fix ? WHere are they getting these people to program their routers ? Orbi used to be a great product and they have ruined it with this poor solution.
- MstrbigAug 26, 2020Masterwhat OS are you on? If using IE browser it is no longer supported. Suggest installing the new Edge Chromium.
What are your PC settings and what model Orbi and firmware do you have.
BTW it's better to not insult the ones that are trying to help. 80% of problems are user error.- relberfeldAug 26, 2020Apprentice
I have a mac. on safari. and this also fails on the iphone app. and other laptops. so it is not a user error if I didnt change anything. also fails on chrome. this is clearlhy a remote access issue as it didnt start until netgear had the brilliant idea to change remote access. I dont mean to insult anyone but the answer of "reboot and reinstall" is in the same league as unplug your PC and turn it back on.
