HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
May 05, 2020Guru - Experienced User
What browser are you using? Try IE11, Firefox or Opera.
Besure to clear all browser caches.
Reboot the RBR.
What FW version are you using?
Try a different PC or laptop.
relberfeld
Aug 26, 2020Apprentice
this is total BS. Netgear changes the name of access control and fails to test this new "secured access" - results in constant 500 internal server errors. Then a "tech" person says the answer is to reset the router and that fixes it. How is that a fix ? WHere are they getting these people to program their routers ? Orbi used to be a great product and they have ruined it with this poor solution.
