HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
relberfeld
Aug 26, 2020Apprentice
this is total BS. Netgear changes the name of access control and fails to test this new "secured access" - results in constant 500 internal server errors. Then a "tech" person says the answer is to reset the router and that fixes it. How is that a fix ? WHere are they getting these people to program their routers ? Orbi used to be a great product and they have ruined it with this poor solution.
Mstrbig
Aug 26, 2020Master
what OS are you on? If using IE browser it is no longer supported. Suggest installing the new Edge Chromium.
What are your PC settings and what model Orbi and firmware do you have.
BTW it's better to not insult the ones that are trying to help. 80% of problems are user error.
- relberfeldAug 26, 2020Apprentice
I have a mac. on safari. and this also fails on the iphone app. and other laptops. so it is not a user error if I didnt change anything. also fails on chrome. this is clearlhy a remote access issue as it didnt start until netgear had the brilliant idea to change remote access. I dont mean to insult anyone but the answer of "reboot and reinstall" is in the same league as unplug your PC and turn it back on.
- MstrbigAug 26, 2020Master
relberfeld wrote:I have a mac. on safari. and this also fails on the iphone app. and other laptops. so it is not a user error if I didnt change anything. also fails on chrome. this is clearlhy a remote access issue as it didnt start until netgear had the brilliant idea to change remote access. I dont mean to insult anyone but the answer of "reboot and reinstall" is in the same league as unplug your PC and turn it back on.
Undestood. So you are using an Imac?
I'm not seeing where netgear changed anything. When you say remote access are you referring to accessing your Orbi system remotely?
What URL are you using that gives you the 500 error?
Also if WIFI, go on the PC and flush DNS, forget the WIFI network, search for WIFI network and rejoin WIFI network.
Forgot one thing: Clear Browser Cache
No, Mac, not Imac. and it also fails on a windows PC, the ORBI iphone app also fails to connect. a direct ip address connection fails to connect. both of these worked consistently until netgear changed to the new "secure" access anywhere for all their platforms, and updated to the current firmware. Netgear confirmed the change, so I am not sure why you say nothing changed.
