HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
relberfeld
Sep 03, 2020Apprentice
it is so obvious that this is a netgear problem. even to a casual observer. all the noise about network issues and non-technical related questions is letting netgear off the hook.
netgear FIX this or the google product will replace yours.
Thedataman
Sep 26, 2020Initiate
Has there been any resolution to this issue. I just woke up - noticed was having issues with certain websites and went to login to iPhone app and telling me password incorrect? That’s not right I am using facial recognition. Go to login using IP address of router / internal 500 error? I was literally on the iPhone app last night and all was good? Am I really being expected to rest this setup to factory conditions and reinstall the entire mesh network for something I did not do? What are my next steps??
- FURRYe38Sep 26, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update?
Thedataman wrote:
Has there been any resolution to this issue. I just woke up - noticed was having issues with certain websites and went to login to iPhone app and telling me password incorrect? That’s not right I am using facial recognition. Go to login using IP address of router / internal 500 error? I was literally on the iPhone app last night and all was good? Am I really being expected to rest this setup to factory conditions and reinstall the entire mesh network for something I did not do? What are my next steps?? - Blanca_OSep 29, 2020NETGEAR Employee Retired
Hi HHassell relberfeld Fuq Thedataman
We are currently checking on this.
Did you enable NETGEAR Armor?
Were you able to take note of the firmware version?
Blanca
Community Team- danscarfeSep 30, 2020Tutor
I'm having the exact same issues, all of a sudden. 500 internal server error on router. App says it can't connect. I can still login to satellites via the brower, which report the router as being fine.
And no, this isn't a problem with the laptop, or the brower, or anything like that. A 500 error means something very bad happened in the webserver on the router. It's clearly a firmware upgrade gone wrong. I can't login either to see what firmware is running
- FURRYe38Sep 30, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has Armor or Circle been enabled on the RBR?
danscarfe wrote:I'm having the exact same issues, all of a sudden. 500 internal server error on router. App says it can't connect. I can still login to satellites via the brower, which report the router as being fine.
