HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
Blanca_O
Sep 29, 2020NETGEAR Employee Retired
Hi HHassell relberfeld Fuq Thedataman
We are currently checking on this.
Did you enable NETGEAR Armor?
Were you able to take note of the firmware version?
Blanca
Community Team
danscarfe
Sep 30, 2020Tutor
I'm having the exact same issues, all of a sudden. 500 internal server error on router. App says it can't connect. I can still login to satellites via the brower, which report the router as being fine.
And no, this isn't a problem with the laptop, or the brower, or anything like that. A 500 error means something very bad happened in the webserver on the router. It's clearly a firmware upgrade gone wrong. I can't login either to see what firmware is running
- FURRYe38Sep 30, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has Armor or Circle been enabled on the RBR?
danscarfe wrote:I'm having the exact same issues, all of a sudden. 500 internal server error on router. App says it can't connect. I can still login to satellites via the brower, which report the router as being fine.
- danscarfeSep 30, 2020TutorI don't know what version is loaded, or that it even did an upgrade, everything just went screwy. Armor and Circle were both on. Standard Rogers modem.
I haven't factory reset it nor should users really have to! I've finally given up on my setup and bought nest wifi which instantly works perfectly! - FURRYe38Oct 01, 2020Guru - Experienced User
Well something we would need more information on regarding your modem.
Armor and Circle have been known to cause problems.
Factory resets are a valid and integral part of troubleshooting and does help resolve problems. I would recommend a factory reset and setup from scratch. This time, do not enable Armor or Circle. Be sure to clear out all browser caches.
Good Luck.
