HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
Sep 30, 2020Guru - Experienced User
Has Armor or Circle been enabled on the RBR?
danscarfe wrote:I'm having the exact same issues, all of a sudden. 500 internal server error on router. App says it can't connect. I can still login to satellites via the brower, which report the router as being fine.
And no, this isn't a problem with the laptop, or the brower, or anything like that. A 500 error means something very bad happened in the webserver on the router. It's clearly a firmware upgrade gone wrong. I can't login either to see what firmware is running
danscarfe
Sep 30, 2020Tutor
I don't know what version is loaded, or that it even did an upgrade, everything just went screwy. Armor and Circle were both on. Standard Rogers modem.
I haven't factory reset it nor should users really have to! I've finally given up on my setup and bought nest wifi which instantly works perfectly!
- FURRYe38Oct 01, 2020Guru - Experienced User
Well something we would need more information on regarding your modem.
Armor and Circle have been known to cause problems.
Factory resets are a valid and integral part of troubleshooting and does help resolve problems. I would recommend a factory reset and setup from scratch. This time, do not enable Armor or Circle. Be sure to clear out all browser caches.
Good Luck.
