HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
danscarfe
Oct 01, 2020Tutor
I don't know what version is loaded, or that it even did an upgrade, everything just went screwy. Armor and Circle were both on. Standard Rogers modem.
I haven't factory reset it nor should users really have to! I've finally given up on my setup and bought nest wifi which instantly works perfectly!
Oct 01, 2020Guru - Experienced User
Well something we would need more information on regarding your modem.
Armor and Circle have been known to cause problems.
Factory resets are a valid and integral part of troubleshooting and does help resolve problems. I would recommend a factory reset and setup from scratch. This time, do not enable Armor or Circle. Be sure to clear out all browser caches.
Good Luck.
