HHassell
May 05, 2020Follower
Geting 500 Internal Server Error from Access Control
Can't access internet from one Lap top. When I go to Access Control to see if it's blocked I get "500 Internal Server Error"
jhiggins1123
Jan 13, 2021Guide
I have an RBR40. Im trying to update the firmware from 2.5.1.22 to 2.6.1.36. When i hit the upload button, I get the same 500 Internal server error
Jan 13, 2021Guru - Experienced User
What browser are you using? Be sure to clear out all browser caches then exit the browser then try again.
Try IE11, Edge, Firefox or Opera GX
Try powering OFF the ISP modem and RBR for 30 seconds then back on then try the Update All button.
jhiggins1123 wrote:I have an RBR40. Im trying to update the firmware from 2.5.1.22 to 2.6.1.36. When i hit the upload button, I get the same 500 Internal server error
- pavel_lishinMay 01, 2021Aspirant
I am begging you all to understand that a 500 error is incredibly unlikely to be caused by a browser cache issue.
- FURRYe38May 01, 2021Guru - Experienced User
WIth Orbi, could be anything. Never seen this problem with mine.
If your having problems with your system, and can't get it fixed, contact NG support for there help and information.
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.Good luck.
pavel_lishin wrote:I am begging you all to understand that a 500 error is incredibly unlikely to be caused by a browser cache issue.
- jhiggins1123May 01, 2021Guide
Thanks all for the responses, but Ive since replaced the Orbi.
