Texasbill
Oct 28, 2019Aspirant
Getting error 404 on some websites
Hi, I use a Netgear Nighthawk M1 connected to the ATT network. I use it as a stand-alone hotspot when I travel and at my home connected by Ethernet to my Orbi system. It was working perfectly at ...
ekhalil
Oct 28, 2019Master
1. Just to confirm, can you please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
What will be the first two hops?
2. What is the setting of the DNS configuration in Orbi? This issue can very well be caused by the DNS configuration. Try different settings (e.g. try 8.8.8.8 as DNS) and see if things improve.
Texasbill
Oct 29, 2019Aspirant
Here is what I get:
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
1 10.0.0.1 (10.0.0.1) 4.380 ms 3.041 ms 3.656 ms
2 10.78.87.1 (10.78.87.1) 4.760 ms 5.953 ms 4.382 ms
3 172.26.96.161 (172.26.96.161) 210.314 ms 228.399 ms 197.444 ms
4 172.17.32.60 (172.17.32.60) 320.297 ms 530.741 ms 339.404 ms
5 12.249.2.1 (12.249.2.1) 407.724 ms 274.091 ms 292.604 ms
DNS:
DNS Server 172.26.38.1
Type DHCP
I appreciate your help!
6 12.83.179.194 (12.83.179.194) 395.193 ms 283.434 ms 263.141 ms
7 12.122.85.193 (12.122.85.193) 282.772 ms 224.399 ms 265.629 ms
8 206.121.120.90 (206.121.120.90) 296.069 ms
206.121.120.86 (206.121.120.86) 360.121 ms
206.121.120.90 (206.121.120.90) 240.633 ms
- ekhalilOct 29, 2019Master
Texasbill wrote:Here is what I get:
Very strange that the first 4 hops are private IP addresses! I think the 10.0.0.1 is Orbi's gateway IP address, I wonder what the 10.78.87.1 is? Can it be the Nighthawk's way out?
Can you please connect a computer to Nighthawk directly and make the same traceroute command.
Also, have you tried to change the DNS IP address in the web GUI under >> ADVANCED >> Setup >> Internet Setup >> to "Use these DNS Servers and try 8.8.8.8 as primary and 8.8.4.4 as secondary and see if you will get any improvement.
